fuel gauge reads high...
Hi
I just read torstens post
. And I saw that the fuel gauge was changed 87 + on up.
I had to get my truck on the road so my son can have my explorer, anyways I was having trouble getting the larger hole sending unit for my 85 f250.
So I bought a small hole tank and a small hole sending unit.both from spectre.
but it always reads 2x as high as it should .
New connector and ground....
A few questions, 1) what size tank are you using? 2) can you verify that it is the right sending unit? I did the same thing on my truck and got the wrong sending unit, it was meant for a smaller tank, therefore not drawing gas from the bottom and not giving me the correct fuel gauge readings. Mine reads high at first then quickly drops down to E with a 1/4 of a tank left.
If the gauge is indicating 2x as high as it should, bending the arm up won't work. Neither will bending it down.
For example when the float arm is against the lower stop, the gauge should be on E. Bending the arm up would make it even less accurate than it is now.
Look for some method of adjusting the arm itself down relative to the "axle" of the sender. Repops from 60s and 70s era senders have a set screw on the arm attachment for this purpose. Took me about 5 years to figure that one out. Hope this helps.
Odisvan
04-05-2016 09:25 AM
thegringo
17
03-22-2014 10:49 PM
cwpowell
06-16-2010 07:34 AM
