Oil Type and FILTER!
Old 11-20-2015, 06:49 PM
shermy452's Avatar
shermy452
shermy452 is offline
Hey guys!
So i guess the guy that had this truck before me claimed he was using amsoil and just got it done. that was in may. I've prob put 5000 miles on it tops and the oil is disgusting. Guessing i should of did the change then because pressure seems to be low. I added a quart of 10w-30 synthetic just til I can get to the store. What oil and oil filter is everyone using? Specifically oil filter because i don't know the fit! thanks guys!
Old 11-20-2015, 07:15 PM
big-ugly's Avatar
big-ugly
big-ugly is offline
I run 15W40 diesel Cenex oil. I like certain properties this oil has for my old 1968 engine. Ultimately only you can decide what to run in your engine. As for the filter, it depends what engine you have. I have a 429 swapped into my truck, so it may be different than what you have. If you would like to give me a little more information, I would be happy to share any information I can with you.
Edit:
Here are a list of oil filters for FE's that *should* work if you have an FE engine (I don't personally own an FE, but this is what my google-fu has taught me)
Puolator L-2081
AC PF20
Wix 51068
NAPA 1068
Fram PH43
Chrysler 3549957
Hastings LF196
If you have a 300/302/351 I know that a Wix 51515 will work. Personally I only use Wix filters, so I can't really comment on anything else here.
Old 11-20-2015, 07:51 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Shell Rotella T 15w-40 and a Motorcraft FL-1A filters on my 65, 68, 70, 71. The '73 gets a Motorcraft FL-300 filter because of a 79 Bronco PS swap.
Old 11-20-2015, 08:13 PM
Steven@nd's Avatar
Steven@nd
Steven@nd is offline
I use Rotella 15w-40 in my 390 FE, Motorcraft FL-1A filter.
Old 11-21-2015, 08:27 AM
Bud Mud's Avatar
Bud Mud
Bud Mud is offline
ive used Valvoline my whole life, 10-40 full syn in our newer cars,standard 10-40 in my older ones, ran 20-50 Valvoline racing oil in all my race cars all with frame filters and never had an issue,my my 88 half ton chevy ran over 350miles before it started smoking a little.
Old 11-21-2015, 09:30 AM
big-ugly's Avatar
big-ugly
big-ugly is offline
Made it a whole 350 miles huh? Pretty good for a chev
Old 11-21-2015, 12:50 PM
shermy452's Avatar
shermy452
i'm running a 302 in it.
Old 11-21-2015, 02:54 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
Napa Premium Gold Filter and cheapy synthetic diesel engine oil, 5w40. And Zinc replacement gunk just in case. I live in mostly winter climates so a light synthetic oil is important to me.
If you've run dino (conventional) oil you might have problems switching to synthetic. When I switch an engine to synthetic, I'll do half and half one change and full synthetic the next. And then swap and change all the leaking gaskets and seals :P
Old 11-21-2015, 03:52 PM
Jchet729's Avatar
Jchet729
Jchet729 is offline
'77/'79/'79 F250's 2 have 400 & 1 has 460 Motocraft or Wix filters usually. I've got Rotella 15w40 t1 in everything but the gf GMC terrain so far and it'll probably have it soon too
Old 11-21-2015, 09:24 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
If its a older flat tappet 302 it will like extra zinc (aka ZDDP). I run Rotella T 15W40 diesel oil in my '78 400 for that reason. NAPA premium filters are good. Make year and model should do it if the engine is original (style).
Old 11-21-2015, 11:52 PM
54Hydro's Avatar
54Hydro
54Hydro is offline
Mobil synthetic blend 10W40 high mileage. I use a Motorcraft FL1A but Baldwin B2 and Napa/Wix 1515 work. I know that in a pinch or for low clearance areas there is a Mopar filter that will work but I can't remember the number. Let the hate begin for mentioning that blasphemy.
Old 11-22-2015, 12:17 AM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
What oil? LOL!!!
Find a multi-grade that makes you happy with your pressure and go from there. I'd probably start with a 10W40 myself. The only time you should have any real concern about what brand you are using is if you want 10,000 mile plus drain intervals. Otherwise anything you would use should provide plenty of protection. Filters? Motorcraft FL-1A! But will use NAPA Gold (Wix) as well.
Old 11-22-2015, 04:38 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Yeah, Motorcraft FL-1 is pretty much the standard. At 5000 miles, the oil should be dirty. Opinions vary, but I don't like full synthetics in an older engine used to dino oil. A lot of times it makes them use oil more than normal.
Old 11-22-2015, 07:55 AM
HIO Silver's Avatar
HIO Silver
Concur. Synthetics are acceptable for modern engines due to close tolerances and modern metallurgy. I run Mobil 1 in my 01 SuperCrew and PT Cruiser (DD).
Conventionals are appropriate for vintage vehicles and OK if their engines have been rebuilt in detail.
Old 11-22-2015, 09:28 AM
dmccorkle911's Avatar
dmccorkle911
dmccorkle911 is offline
WIX Filters for sure and Joe Gibbs Racing oil HR6
Quick Reply: Oil Type and FILTER!
