Paint Suggestions! Color and (Type?)
Hello hello! I'm gonna be painting my truck come spring time, and I'm looking for pictures/suggestions of what color(s) I should go with. Also, I'm wondering about brands/types of paint you guys have used, longevity of the paint including any fading etc...
I know 90% of how well paint lasts is prep work, but I would still like to hear yalls opinions about the paint you've used. Quality, ease of use, price, etc...
Here are some pictures of White B****!
This one probably gives the best idea of the current color. It's more of an off-white, closer to a cream color than just white.
This is a photo from when I was fitting the new fenders on. The fender is snow-white, and the truck like I was saying is more of an off-white.
I have a few ideas churning in the old thinker, but I'd really like yalls suggestions.
At the moment the ideas are:
1) To keep it the same off-white color because I think it's kind of tough looking
2) A nice deep blue
3) Sort of a rough dark green
2) A nice deep blue
I have used paintforcars.com before. It isn't expensive, went on good. Lasted just fine.
As far as color, I would stay in the white family. It is a pain to do the door jamb and engine bay, under hood, etc.
https://www.paintforcars.com/kits_arcticwhite.html
I sprayed Dupont for years but recently have gone to PPG and I will never go back. But that is all personal preference.
As for longevity? Base/Clear no doubt about it.
Do NOT use Single stage enamel. It is OLD technology from the 80s
Do you guys have any tips in particular? Anything specific to vehicular painting? Is there any difference in technique for spraying large areas like bedside or hood?
I will probably end up spraying the off white, to match door jams like you were saying. But I'll still have to spray under hood and fenders any way because they are all different colors haha
The truck is currently teal, snow white, maroon, and off white hahah
Would you suggest doing it panel by panel? I was thinking that was the best way to do it, so I could correct any mistakes that I make.
I could do either way...
As for your "cheat", do you think it would be worth buying the extra paint, rather than taking the time to just do it with the base and top?
If I recall Eastwood Company has some decent videos and tips....may want to give them a look. I have never used their paints, only the frame coatings and tools..but they have some decent instructional stuff on the site.
FWIW, I use mostly DuPont..always have.
EDIT: Just a thought... prep work is EVERYTHING. What you do under the paint matters more than the paint. You can spray paint smooth as glass over a crappy prepped vehicle, and it will look crappy... seriously, prep work is EVERYTHING.
I agree completely. I'm going to be spending the winter doing all the body and prep work and will be spraying in the spring. What would you guys suggest as a good cleaning product for after the bodywork is done?
Thanks for all the replies BTW. I posted this here because not many people respond in the Paint/Body section!
When I redid my 97, I painted the back side of each panel, then assembled the truck. Then painted the complete outside(caB, nose, doors, hood). I did this for 2 reasons. 1. So the paint matched. Variances in air pressure, temp and humidity all play a fact in how the metallic will spray, flow and lay down.(this was metallic silver and white) 2. It takes Far longer to do each piece separate.
NOW. I am in the process of redoing my Ranger. That I am doing in pieces. A couple reasons for this as well. 1. I have many "new" panels for the truck, and I wanted to drive the truck as long as possible before tearing it down. SO I did the new bed and tailgate 1st, then the hood and fenders, then the passenger doors and the drivers supercab door, then the grill and visor. All that is left now is the drivers door and cab. This is white so matching is not a real issue
The single stage paint for the door jams will be fine. It only gets sunlight when opening/closing the door, same for underhood. But the rest of the truck gets a Constant array of sunlight. Single stage also covers better. Typically one to twp passed with single. base clear will take 4-5
