enigne won't start after reinstallation
So I posted a while back about fixing all the leaks I had and what I was going to do. I finally completed all the repairs and reinstalled the engine and it won't start. Cranked a bunch and checked oil level in hpop its good so I pulled plugs in oil rails there is oil present there, cracked the yellow valve on fuel bowel there is fuel there. unplugged the icp sensor and cranked more still no indication of wanting to start. PLEASE HELP.
i have wts light check engine light with p1280 because of icp being unplugged fuel pump runs ill throw a gauge on it and see what kind of pressure is there it was at 40 to 60 psi before i tore every thing apart that is at the upper port on fuel bowel i have a gauge hooked in the drivers side oil rail it was at 3500 before tearing it apart and is at 0 psi now its a 500psi gauge so probably not going to register real low pressure I've been over all the connectors but ill check them again
on
Make sure the IPR is connected and the tin nut is in place.
yes the ipr solenoid is there and tight i did have the hpop out and when i reinstalled it i torqued it to 89 i believe i looked it up as i went. I just resealed every thing fuel bowl, hpop, rebuilt the ipr, oil pan, oil cooler, injector orings, turbo was rebuilt, front main, front cover etc i even swapped out the check ball in the hpop.
