Trouble filling gas tank 2009 SD 5.4
Hey all, read a lot about trouble filling gas tanks after a while on these trucks. It could be this,it could be that. They may have fixed the issue but never reply back to say exactly what cause was. Heard it could be the filler neck, vapor canister, or solinoid.
There is also some type of small canister on the driver's side firewall above the brake booster, what is that ?
I'm having this problem now and just wonder what you all have found to be the problem.
Thanks a lot, Duane
Thanks a lot, Duane
Thanks for the reply, did this solve the issue ?
The solenoid above the brake booster lets the vapors from the tank into the intake manifold to be burned up. I have the same issue on my 08. I replaced the solenoid first and it did nothing. I did figure out that if you take the lower hose off the solenoid before you pump your gas it fills just fine. Don't forget to reconnect it though before you drive. Mine has been like this for 2 years now I've just been too lazy to replace the evap canister
Thanks for the info so far !
on
Did you also blow out all the lines, particularly the lines from the evap canister to the tank and the line from the tank to the fuel filler [there normally is a large one and a small one, the small one will sometimes get things blocking it]?
The solenoid under the hood should you be able to blow through that ?
Thanks
Think I'm going to change out the canister. I hate to chance $120 but I think it may be worth it.
Filled up today and removed the bottom hose. Works like a charm but don't want to have to do this everytime. Thanks for the heads up.
N_fini_T
21
03-03-2003 09:54 AM
