Help with electric problem 1997 f150
Hi can you help i own a 1997 ford f150 V6 engine and i have problems with the electrics.I turn the key on and the engine starts up runs great but i then look at the gauges and not one moves at all the.No fuel when i have just filled up,no tep,no oil,no battery all read nil.I went a drive and the speedo reads 0 it does not move but the truck drives great.Could it be a fuse,does a fuse control the gauges,if so any idea which one it could be.I have lifted the hood and under the hood on the drivers side there is a box with small and larger fuses.There is one that is very small and the colour is white thats blown.Would you no what that fuse is for.I hope you can understand me as im in the Uk england and that you for any help
