Y block Front Engine Mounts
How many different mounts are there for F100 Y blocks? I have one off a 56 272 (small) and a different one from a 64 292 (larger). Then I'm checking CL and there's this.
56 Y Block
What's the pin in the front for? And what if any of then interchange. The rubber mount on the 56 272 is under the vibration damper, the rubber mount is about 1 1/2 in front of the damper on the 64 292.
56 Y Block
56 Y Block
56 Y Block
I have a 55 with Y Block (239) and this mount is not like that. I would recommend going on Dennis Carpenter, Mid Fifty and Mac's to determine which mount is correct for your truck.
WALFORD'S 56
11-01-2008 06:18 PM
HT32BSX115
09-29-2008 10:32 AM
