09 F250 5.4 83k plug change
[QUOTE=Leon82;15773304]The two on the bottom look like they have seen better days.
I replaced them with the motorcraft plugs
Hey Leon, I also have the long thread plugs in mine.
Did you change them with the motor slightly warm (as Ford says you have to do), or when it was cold?
Also, I was wondering if you used anti-seize when you put the new ones in or followed Ford's instructions to not use any?
What did you toque them to?
Thanks in advance, Tom
[QUOTE=f250mtnbikr;15780542]
The motor was run about 3 house earlier. But it wasn't warm. A read in another thread here the dealer said to do it mildy warm.
The plug box has the spec on it, I think 7-12 ft pounds.
I didn't use anti seize also from what I've read.
I had to work them out for the first 2 or 3 turns nice and easilly. Going back and forth. Also I blew out the hole before removing the plugs
Leon, thanks for the reply.
I have needed to change mine for a while now, but had other more pressing things I needed to do on the truck.
Glad to hear the job went well and no issues with following Ford's recommended procedure.
I hope to get to my V10 in the next month.
Have a great day, Tom
