Need help - stalls randomly - replaced CPS, ICP, IPR
Ok, I will try to be succinct:
2001 Excursion 7.3 - stalls randomly, sometimes will not start. After the IPR was replaced it was rough for about 4 miles (I thought maybe air in the system), next 40 miles was flawless with 3 stops and restarts. Then it sat for a few hours and I went to leave again and the problem was off and on again for another 5 mile drive. Now it won't start in the driveway. It will start if I disconnect the ICP but the idle is still a little rough.
I replaced the normal culprits after a lot of searching on here:
I'm thinking it may be some electrical issue/short or a fuel issue at this point, bowl is full and the filter is fairly new (few thousand miles). I haven't done the Hutch mod, but have over 1/2 a tank.
I'm trying to get this going as quick as I can so I don't want to waste too much time, but I also don't want to miss a critical troubleshooting step to take.
Below are my thoughts on the next steps.
Any feedback is greatly appreciated - the answer may be in this forum but I'm running into information overload and would like a planned approach to continue troubleshooting.
- CPS - replaced with autozone part, thought maybe it was bad new so went to ford and replaced with official part from the dealer
- ICP - had oil in the plug and it would idle better removed so I replaced the plug and as much wire as I could - soldered, heat shrunk, good connections - both the pigtail and sensor came from Ford dealer
- IPR - replaced with part from the Ford Dealer (FYI - 1 1/8" 1/2" drive craftsman deep socket from sears fit in the ratchet and on the part).
- Grounds - found somewhere that the ground on the firewall for the windshield wipers can interfere with the CPS so I pulled it, clean the connections and made sure it was tight and secure.
- No check engine light now - I received a few through the process, but did not clear them and there are no codes at this time (self cleared on the 40 mile drive)
- Research and test fuel pressure
- Tow it somewhere to test each injector - I only have Torque pro to read codes and engine status
- If fuel delivery checks out ok, start testing wire by wire on all of the above parts.
I will try to research, locate and try the fuel bowl heater - wasn't aware of this one. No chip and injectors, intake and exhaust - all are stock.
So, I lied, after the last engine stumble and now will not restart, I have some codes. I'm not sure if some of these are from me starting it with the ICP unplugged to test that.
P0683 - Glow Plug Control Module
P1211 - injector control pressure higher than desired (engine on)
P1210 - injector control pressure higher than desired (engine off)
P1316 - Injector circuit/IDM codes detected
P1670 - miscommunication between the IDM and PCM
P1280 - indicates injector control signal circuit out of range low
With your codes and the random start stall, I'd start by checking for chaffed or brittle wires on the ICP and IPR. Also make sure the tin nut is secure on the back of the IPR.
Ignore the P1670 for now, but for future reference, there's no difference in the Excursion and the F250/F350 IDM's.
Thanks for all of the feedback - please keep it coming.
Batteries are 2 years old, I'm charging on and off but I have drained them to the point that she is slow to turnover a couple times during this troubleshooting.
Unplugged the fuel bowl heater - no improvement
Visually inspected wires at ICP and IPR and neither appear chafed or broken, tin nut is tight on the back of the IPR an no seepage around the o-ring after the recent replacement.
Cleared codes - P1670 is gone and not coming back when I attempt to start now.
Current status: She starts and runs for just a few seconds and shuts off, no check engine light
I believe my next step is to find a scanner that will run a buzz test - from researching, if there are none successful then the IDM is shot, otherwise I need to step back and re-think.
Harness across the valve cover, is this worth breaking into the factory sheathing? The images I've searched for looked much worse than this (also shown is inside the plug [some pins appear to be covered in a white powder substance] and the wires at the IDM):
That white stuff should be cleaned off with contact cleaner. I theorize it's just old dried-out dielectric grease, but I am unsure.
I think we have multiple common issues here - UVCH and thick oil on a cool day. The UVCH link in my signature should help out, and the last link in my signature is a great thing to have with your OBDII gauges.
Have you plugged in the engine heater for about 2-3 hours while you wait for the batteries to charge?
Thanks Tugly, I'll get to reading and ohm test using those images for reference.
I forgot to mention, but both UVCHs have been replaced - one in late 2014 and one in early 2015 no issues since except this recent situation. It's been in the 80s here in central Texas.
EDIT: By the way Tugly - that is quite a collection of information in your signature, when I get through this one I'm going to steal a couple to share as well!!! Reps sent.
