drop washer fluid hose in cylinder !
Ick. Triple ick. When I worked on well pumps long ago, I learned on important fact that sticks with me to this day: If there is something you don't want in the hole - you can drop it 6 feet from the hole and it will land in there anyway.
For the readers (a little late for pechroc1): I use small tubing no shorter than about a foot any time I work around open valve covers. While the injector nozzle and GP holes are quite small, the openings to the lifters are NOT.
If you dropped a steel piece in there, magnets can help. Not so much with the rubber, plastic, and brass stuff. Is the tubing poly or rubber? If you lift the piston, you won't be able to stand the tube up to fit it out from whence it came.
Best to leave the piston where it is, and locate a fine-tip dental pick to play "Operation". You might need both the injector and the GP out in order to come at it "in stereo" - working one tool to push it to the other. You might also use one hole with a borescope to see what you are doing with the tool. The injector nozzle hole will have more maneuverability with a tool than the GP hole.
I was thinking a borescope with a needle attached to it.
The ones at home depot are too big to get thru. I was looking for something local. all the ones on ebay that attach to your phone (7mm or 5.5mm head) are in China and take 2 weeks to get here
Just ordered one off Amazon for 45 bucks. It will be here tomorrow. Let you guys know how it turns out. Wish me luck.
That sucks! If it was me I would try to use my shop vac with the cone adapter and tape a heater hose or something to try to concentrate the pulling power to a small area. U would need to not let the vac run too long restricted because the motor needs the air to cool itself. Don't know this would work because the windshield hose isn't solid has a hole in it. But good luck hope u figure out how to get it out.
Kyle
Behind the cup, there is steel - not a larger opening to the cylinder.
The dissolved mess would flow into the cylinder and maybe work it's way into the oil. This is a great idea and may very well work, but an oil change would be in order. As for vacuuming - fuel, oil, and any other chemicals like acetone or MEK would make for a spectacular show somewhere in the area of the vacuum motor. In the immortal words of Adam Savage - "Am I missing an eyebrow?"
