Maximum rear tire size without effecting frame
A 345/45-17 tire is around 13.6 inches wide. A stock bed/fender combo allows for a max 11 inches clearance. There is room to tub the bed to gain the clearance but a lot depends on the rear suspension width...leaf springs hang outside the frame and take up some clearance whereas a 4-link may give you some more room. Frame width is 34 inches, bed width is a bit over 49 inches...from frame to fender can be as much as (((50 - 34)/2)+11) = 19 inches. I think that you need to measure your own frame to decide how much room you have to work with.
No need to install rear fenders...the dimension that you need is the distance between the frame and the outer extremes of the suspension. IE, if your 4-link bars/mounts extend 4 inches from the frame then subtract that 4 inches from the max distance of 19 inches which will give you 15 inches clearance. Also consider the clearance you want between the fender and the frame/bed. 1/2 inch is tight but if you hold close your tolerances it will work.
I'm liking the progress you've made on the rear end. I'm considering going with a TCI frame myself. What ultimately made you decide to go that route? Did you make any modifications to the build or was it ordered as a tubed, stock setup?
I went with a Full FATMAN suspension.
my reasoning was after looking at Resale values, it seems they command a higher dollar.
plus FATMAN is 15 mins from my house.
yes it costs a little more but well worth it.
the tubs came from Dan Carpenter also 30 mins from my home...easy to install
oh Dennis carpenter is 20 mins from the house too.
i guess i'm lucky.
i guess i'm lucky.
fisherman_chuck
23
06-25-2015 05:48 PM
randrford
08-16-2009 04:04 PM
ksmith203
03-13-2007 08:04 PM
53f100owner
18
01-23-2007 12:46 PM
