1979 f350
Old 10-24-2015, 05:55 PM
hwyhogg's Avatar
hwyhogg
hwyhogg is offline
1979 f350
Anyone know the available gear ratios in a 1979 f350 with a 460 and c6?
Thanks
Old 10-25-2015, 07:52 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
What does the axle tag say? What code #'s are on the top r/h corner of the warranty plate riveted to the door?
Old 10-25-2015, 10:05 AM
tabascom16's Avatar
tabascom16
tabascom16 is offline
As far as I know the only two options were 3.50 and 4.10 gears. Maybe they did offer 4.56 gears in an F350?
Just jack up one tire and put the transmission in neutral. Rotate the tire one full revolution and count how many times the driveshaft rotates and then multiply by 2.
For example:
3.50 - spin the tire one revolution and the driveshaft will turn about 1.75 times
4.11 - just a wee bit past 2 full revolutions
4.56 - about 2 and 1/4 revolutions
Old 10-25-2015, 11:08 AM
PA74F250's Avatar
PA74F250
PA74F250 is offline
Seems like auto trucks are typically 3.54 and sticks were 4.10. I may be wrong but from what I've come across that seems to be the way they came. I suppose you could order it how you wanted it.
irhunter
04-24-2011 06:58 PM
tcook487
07-31-2003 09:46 AM
hodgesmarvin
02-17-2001 04:02 PM
Quick Reply: 1979 f350
