?s for Mr. Gary lewis
Old 10-25-2015, 11:00 PM
arkredneck's Avatar
arkredneck
arkredneck is offline
Also I'm pretty sure no vaccuum leak because when I hook the vacuum gauge up the needle stays steady. Is there any reason I shouldn't follow this advice for tuning?
http://classicinlines.com/vacuum.asp
Old 10-26-2015, 01:33 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Not necessarily, a low steady reading would indicate a vacuum leak. Not sure about sixes, but a healthy stock V8 will pull about 19" or 20" at sea level. How much vacuum is the engine pulling in neutral, at the stock, OEM idle RPM specification?
That's a great resource website you linked btw, vacuum gauges are a GREAT way to quickly perform accurate engine diagnosis (and best of all, easily and cheaply.) All I can say is try the suggestions for setting ignition timing and carb adjustment.
Want to be careful, check for ping or detonation both at acceleration and cruise after adjustment, and back off a little more if necessary. Most people find a little more ignition advance than the stock setting preferable. May have to run a higher octane to advance it farther, also check for starter kickback, especially when engine is fully warmed up.
Old 10-26-2015, 05:54 AM
arkredneck's Avatar
arkredneck
It's running like 22" on the vacuum gauge in park at around 700 rpm.
Old 10-26-2015, 10:12 AM
Tedster9's Avatar
Tedster9
Tedster9 is offline
OK, no vacuum leak you are correct,
Old 11-03-2015, 03:06 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Originally Posted by Gary Lewis
I don't run loud exhaust. But, it might be possible to add a detonation sensor from a later engine, or maybe there's an aftermarket sensor - I don't know. I just run a fairly quiet Magnaflow muffler and listen for pinging - which usually happens long before detonation.
Gary,
What Magnaflow mufflers do you run? I'd like to add duals on my F100.
Old 11-03-2015, 06:02 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
BJ - I think it is a 22" single-in/dual-out. I can measure it tomorrow, but that's the size I remember.
I went with the single/dual arrangement because that's what was on Rusty when I got him and it was a lot easier. But, it had a 14" Flowmaster that was flatulent. Awful. And the Magnaflow was a huge improvement. Huge.
Old 11-03-2015, 08:06 PM
bjmayberry2
Just getting too old for that steady drown while on the road. I fall asleep easy enough I don't need to fall asleep driving. Don't mind a light rumble when I get on it but not constant. OBTW I've got an H pipe off the stock manifolds so that's why I'm going duals. Thinking about 2 1/4" front to back.
Old 11-03-2015, 09:10 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Sounds like a good plan. And I agree that it needs to rumble a bit when on it, but the steady stuff is for kids. And that's why I like Magnaflows. They will rumble but aren't noisy.
Old 11-03-2015, 10:34 PM
bjmayberry2
Where'd you place your muffler? I think that has some bearing on noise too!
MIKES 68 F100
10-17-2011 06:16 PM
Bart8109
01-16-2009 02:02 AM
adamsre
20
07-20-2005 05:15 PM
darkknight9
Electrical Systems/Wiring
02-11-2005 12:27 PM
steeldust
05-17-2004 05:40 PM
Quick Reply: ?s for Mr. Gary lewis
