1 ton brake upgrades?
Old 10-21-2015, 10:05 AM
blk450er's Avatar
blk450er
blk450er is offline
Is there a kit or anything that will bolt up to the brakes to 1) elimante the rear drums and convert to disk 2) replace front calipers/rotors to better upgraded brakes on my 79 350?
Old 10-21-2015, 10:32 AM
blk450er's Avatar
blk450er
blk450er is offline
I've seen on a post here a guy using explorer brakes but his is a 1/2 ton.
Old 10-21-2015, 11:28 AM
co425's Avatar
co425
co425 is offline
What rear axle are you running? Dana 70? Dual rear wheel, or single?
Old 10-21-2015, 11:31 AM
blk450er's Avatar
blk450er
blk450er is offline
Single. Not sure on the 70 or not. I could get a pic or the stampings off of it
Old 10-21-2015, 01:04 PM
privateer, eh's Avatar
privateer, eh
privateer, eh is online now
If you want a complete improvement to the rear start looking for a 92 or newer Sterling with disc brakes and posi. In the future, state if it's a dually 350 or a srw, there are 2 frame widths involved and a different brake bias set up.
Old 10-21-2015, 01:47 PM
blk450er's Avatar
blk450er
blk450er is offline
Gotcha
Here is the rear
Assuming the 60 is for a Dana 60
Here's the front. Has crud all over it that I'd have to clean off for the numbers, but someone told me it looks like a 44. I don't know for sure
Old 10-21-2015, 04:03 PM
co425's Avatar
co425
co425 is offline
Yes you have a Dana 44 front and a Dana 60 rear.
These guys are one of my local off road shops. I have bought parts from them before with good customer service.
Here ya go. Ford Dana 60 Rear Disc Brake Brackets, '77 & Newer - RuffStuff Specialties
Old 10-21-2015, 08:29 PM
blk450er's Avatar
blk450er
blk450er is offline
I also have another front axle that the guy had that came with it. He said its a Dana 60
Old 10-21-2015, 11:33 PM
co425's Avatar
co425
co425 is offline
If it is the correct 78-79 Dana 60 front you scored. That is around $1500.00 in my area if you can even find one local.
Old 10-22-2015, 09:09 AM
blk450er's Avatar
blk450er
blk450er is offline
Don't know what it is and if it's from a 78-79. I'll have to get some picks of it also. How can you tell if it is?
Old 10-22-2015, 11:57 AM
blk450er's Avatar
blk450er
blk450er is offline
Here's the front axle
Old 10-22-2015, 12:38 PM
co425's Avatar
co425
co425 is offline
Measure the center pins of the spring perches and make sure they match up to your front springs. However just looking at the pictures I'm pretty sure it's the proper 78-79 Dana 60 front. Be aware though, swapping to that front axle may require you to shorten your drive shaft. Since you have a high pinion Dana 44 you may not have to.
Old 10-22-2015, 12:53 PM
blk450er's Avatar
blk450er
blk450er is offline
That'd be awesome! I'm making my to-do list of things I want/need to do to the truck now so the slow project can get things checked off the list. Eventually the axle will get swapped
Old 10-22-2015, 03:18 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
To verify everything, use the axle's BOM (Bill of Material) and hit up dana's website. or post here and someone can look it up. Here's an example of my '77 f250 dana 44:
Old 10-22-2015, 03:56 PM
co425's Avatar
co425
co425 is offline
Forgot about the BOM# good idea.
Quick Reply: 1 ton brake upgrades?
