Where is closest switched power wire . . .
There is a Yellow with green stripe wire that goes to the center interior lamp assembly that you could use. It is not switched but is controlled by the battery saver relay. It would keep power on the radar detector until the interior lights shut off by the battery saver relay circuit.
You can also use the Green with violet stripe wire if you have a moon roof or the wire is there in the harness.
You could run a wire up the driver side A pillar from the battery junction box under the hood, Fuse 32. It hot in the start and run position.
ahhhhh can't get the fuse tap to work for the radar detector
lonewolftx... this should be a no brainer but I am trying to tap into the internal fuse panel at the radio fuse and I am getting low voltage on the radar.. grounding problem I think BUT I want the fuse tap to be on the fuse that will turn off when the door opens like the radio does.. I am going into #28 on my 2008 F250 but the radar stays on... what did you tap into ?
Thanks for your help.
Chungy
Chungy
Billyboy501
Electrical Systems/Wiring
11-20-2002 05:15 PM
