Problem door locks!
Problem door locks!
So, this 2000 X-Limited that recently bought has another issue that I need help with.
Power door locks. The drivers door is the only door that works, using either the remote fob or the rocket switch on the door. None of the other doors, or the rear lift glass work.
I have a hard time believing that ALL of the individual actuators in each door don't work.
Does the actuator in the drivers door act as a primary? Are all of the other actuators slaved through the drivers door? Is there a relay between the drivers door and the other doors that could be bad?
Thanks in advance-
Thanks in advance-
The following users liked this post:
There's a fix (a thread that was started years ago) in the SuperDuty forum using tin foil. Some guys opt to fix, some to replace.
Stewart
See here for part #: https://www.ford-trucks.com/forums/1...ont-go-up.html
Edit: that looks like it does not include the door lock switch. I will look at the diagrams tomorrow afternoon and verify routing for power to those for you.
Thanks in advance-
Thanks in advance-
I was in the same boat, however, just yesterday I found an old thread about the rear lock/mechanism on the rear doors, I went and checked it and sure enough my rear window was NOT locking. So I removed the interior handle on the hatch,removed the plastic panel got in there with WD-40 and sprayed it well, and after several lock/unlocks with the key Fab the rear lock now works, simple task accomplished! Still trying to get the key tumbler to unfreeze, maybe in good time!
Sorry for the late checkback...
Here are the wiring diagrams for the 2001. The 2000 should not be much different... if at all.
Hope these help, and it looks like there are two relays in the system you should check out. One deals with lock, and the other unlock. They are located in the "relay box". That box is located in the center of the instrument panel behind the dash and under the radio. Your turn signal relay is there as well. To get access to it, you need to remove the trash hangar and the ash tray/cup holder. Then you can just reach in there and pull the relays and check them.
Thanks in advance-
Thanks in advance-
For what it's worth, I just picked up an '01 Excursion with the same issue. Only the driver's side lock worked. After replacing the other 4 lock actuators, they all work fine, so it is possible. Cheap parts and really easy to replace, so it's worth at least pulling yours and testing them.
I did not go with an OEM replacement. Time will tell if that comes back to bite me or not. I picked up a set of 4 from PerformacElectronics on Amazon for $55 shipped. Individual actuators are $19. The price was right and they have a lifetime warranty, so I figured I'd give it a try. So far so good. The actual replacing of the actuators took me less than 10 min per door.
4 Set Power Door Lock Actuator Driver Side Left LH New for Ford Lincoln Mercury | eBay
That one's not bad either; just a few more obstacles to work around. It helps to open the hatch, open the barn doors, then sit down, close the hatch down and work on it that way.
Be careful to not break off the clip holding the actuator- it's a little tricky to release and pull the actuator off at the same time.
Yeah I did the front passenger, both rear doors, and the lift gate. The liftgate isn't bad at all. It's a little bit more difficult to get to the clip that releases the actuator, but not hard.
