Brake Controller Question
Bought a brake controller for my 99 Expedition which has the factory 7pin tow package. All the trailer lights work when I hook it up to the truck but I'm not getting power to the trailer brakes. I towed this same trailer last week with my 14 F-150 without issue. The brake controller displays "--" when hooked up. When I manually depress the brake slide on the controller, the brake lights illuminate on the vehicle but again, no brakes. Is there a fuse for the electric brakes?
Here is the link to owners manuals find your 99 and go to page 135 there is a fuse.
JustGiveMeTheDamnManual.com - Your Source For Free Owners Manuals
You don't mention the brake controller make and model, but the bars you describe are likely telling you that the controller isn't 'reading' a trailer. This means that there's a short somewhere in the brake output circuit. The most likely thing to check (other than the fuse Lossoftraction mentioned) is a dirty/damaged/corroded 7-way connector on the Expy.
If you find white or green corrosion on the pins in the connector, there's a good chance the corrosion has migrated to the inside of the connector, preventing signal from getting through.
...and more than likely a relay is also required.
jeepclark
1997-2006 Expedition & Navigator
02-25-2012 03:14 PM
tshrager
01-10-2012 05:55 PM
1duallyman
Electrical Systems/Wiring
06-09-2011 05:49 AM
Eric H
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-13-2010 05:45 PM
