DECODING VIN # TAG ON MY 67 M250
Old 10-13-2015, 01:47 AM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Does anyone know how to decode the vin tag on these trucks ? Thanks.
Old 10-13-2015, 03:31 AM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
vin # F25YRD00994
HORSE POWER IS 179 @ 4000 RPM . I was told its a 390 engine
Old 10-13-2015, 03:40 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by HANDSOME
vin # F25YRD00994
HORSE POWER IS 179 @ 4000 RPM . I was told its a 390 engine.
F25 = F250 2WD
Y = 360 2V
R = San Jose CA Assembly Plant.
D00994 = 1968, assembled March 1968.
On sale day, 352/360 engines magically become 390's!
Warranty Plate: 179 Certified Net HP @ 4,000 RPM
If this was a 1967: Y = 352 2V .. 172 net HP @ 4,000 RPM
Is the truck registered by this VIN, which I assume you found on the Warranty Plate (riveted to the left door face below the latch)?
The problem was, people replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
1967: You push the inside door handles forward to lock the doors. 1968/72's have door lock *****.
Old 10-13-2015, 04:46 AM
Frosty67's Avatar
Frosty67
Frosty67 is offline
Old 10-13-2015, 11:59 AM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Thanks guys, the previous owner passed away so waiting to get registration from widow.Its door locks are push **** on top of door. Totally disheartened its not a 390.
Old 10-13-2015, 12:02 PM
Coastal68's Avatar
Coastal68
Coastal68 is offline
Don't be. Drive it, enjoy it and, when you can, build yourself a rip roaring 390 for it. That's what I'm doing.
Got pics?
Old 10-13-2015, 12:41 PM
NumberDummy
Aw gee whiz...
1968/76 F100/350 360/390 share the same block and heads, the bore is the same (4.05"), the stroke is different: 360 = 3.50" / 390 = 3.78."
So, the only difference between a 360 and 390 are the 390's crank, rods and pistons. EVERYTHING else is the same!
Old 10-13-2015, 12:47 PM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Aw gee whiz...
I'm looking for a 390 now lol. Trying to get pics on here
Old 10-13-2015, 12:53 PM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Got pics?
68 merc m250
Old 10-13-2015, 06:30 PM
wrhinehart's Avatar
wrhinehart
wrhinehart is offline
Nice
Welcome to the nut jobs.
Old 10-13-2015, 07:39 PM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Found a 390 with a 4 barrel carb on it. Numbers on the front of the block is a backwards 501 and 10. Im trying to find out year and if its a 4v. The oil pan has the sump at the back of the engine.
Old 10-13-2015, 08:11 PM
NumberDummy
Reverse 105 could be a 360 or 390...because the bare block is the same!
Prior to the reverse 105, 352 was cast on the block instead. Since all FE engines were cast as 352's, this foundry mark reflected this, but when finished, the engine could be a 352, 390, 410 or 428.
To verify if it's a 390, measure the stroke: 360 = 3.50" / 390 = 3.78."
Old 10-13-2015, 11:02 PM
HANDSOME's Avatar
HANDSOME
HANDSOME is offline
Thanks, will measure the stroke. How do you tell the year of the engine ?
Old 10-13-2015, 11:05 PM
NumberDummy
Somewhere on the block is a casting date code, but it could be months between the time the block was cast, the completed engine was installed in the vehicle.
Old 10-14-2015, 06:34 AM
60F100's Avatar
60F100
60F100 is offline
Before you buy a 390 do the measurements to make sure someone hasn't already put a 390 in it. You may have been told the truth. It probably is a 360 but you never know what has been done to these trucks. The first step is to make sure what you have. I once bought a F250 that was supposed to have a 360 but actually had a 390. You never know.
Quick Reply: DECODING VIN # TAG ON MY 67 M250
