78-79 f250 4x4 steering goes full RH lock with engine start. WTH?
Just got my brothers 460 running & trying to break in the cam, but as soon as the engine starts the steering goes to full RH lock with no input from us. This is a 72 highboy w/steering conversion but the 78-79 control valve housing has been replaced with a '70 2wd unit so things might be wierd. We had a retired ford mechanic who spent a lifetime working on these trucks put it together & he didn't think anything of mixing parts.
I'm wondering if some passage ways may be misaligned or if the parts are incompatible (physically they bolt together just fine) .
Is anyone familiar with the inner intracasies of these steering gears?
This is a 72 highboy w/steering conversion but the 78-79 control valve housing has been replaced with a '70 2wd unit so things might be weird.
I'm wondering if some passage ways may be misaligned or if the parts are incompatible (physically they bolt together just fine).
Power Assist: Two long power steering hoses, pressure and return, route from the pump to the control valve.
Two short power steering hoses, pressure and return, route from the control valve to the ram cylinder.
Power Assist: 1973/75 F100 4WD / 1975 F150 4WD // 1973/76 F250 4WD / 1977 F250 4WD before serial number Y20,001.
Well I'm afraid I dont't have a picture of the setup, but there are only two ports for the lines to go into. the larger port is the return and the smaller port is the pressure. Whatever is messed up must be internal. I don't like tearing into these because I always go to far and then the ball bearing fall out and don't want to go back in and it ends up being a mess.
dirtydeeds77F250
33
11-13-2021 11:11 AM
YoungDumbAndBroke
03-24-2019 09:36 AM
Nktrnl
16
04-12-2014 03:42 AM
