Any problems on 2.7?
Hope it doesn't end up with problems because I may buy a truck with the 2.7 EB in the future.
Which can be shut off from the dash. Engine is too new to know so problems probably won't start showing up until next year or the next few years like the 3.5L has with the timing chain slop, condensation build up in the CAC. I thought I did see some issue but I can't seem to find a link. Only thing I've found is when you do an oil change, pop the oil cartridge a bit let the oil drain back into the block, then drain the oil and wait about 5 minutes or so for all of it to be out. When you add the 6 quarts of oil into the engine wait about 10+ minutes as per owner's manual before you check the level. Last thing you want to do is have 1/2-1 quart or more of oil in the engine and you start having issues.
I shouldn't have to select it each time the engine is started.
As for oil filter, the 6.0 power stroke diesel... Been there still do that. Much easier and cleaner than the traditional spin on.
Josh
I kept it right at 80MPH on roads with that limit. RPM was a tad over 2K as I recall (not counting grades). Nothing annoying, and even doing 80, if I needed to pass a semi or something, I still had power to quickly get past them. Very impressed in that regard.
I will say that at 80, I had a hard time getting better than 21-22mpg on my 2WD unladen. I just have the XLT, so don't know if the fancier models have a boost gauge, but mine doesn't. I think my turbos were probably working at a moderate rate at that speed, which would account for the mileage drop. I forgot my OBDII interface, or I would have plugged the Torque app in as I think that will monitor boost psi.
At under 75MPH (even just barely) and under 2K RPM, mileage went back up to 24-25. So 75 really seems to be a breakpoint on how much the turbos work for just cruising. The lie-o-meter told me that for the 2500 mile trip, I averaged 24.5mpg. That included some 55-65MPH highways and a good bit of rural roads.
I don't know the full specs of the 3.5L, but during the trip I was thinking that if I were to be doing predominately long distance high speed interstates, that one might the better choice given it might not work as hard at 80MPH as the 2.7L. For the occasional vacation though and for my general driving, I have no regrets and am continually impressed with what this little engine can do, especially in a truck.
2.7 EB Power
I have a 6" lift with 35" tires, I have driven it to Vegas three time now.
about a 250mile drive from where i live. That little motor does not even break a sweat. Climbing up the hills, you do not even feel it struggling.
The 2.7 EB is very strong. I avg 22.5 @ 75mph
And whats funny, when i'm cruising up the hills @75-80mph, the V8 trucks that
I pass up are all at high Rev's, try to hold speed. Not knocking V8s, but just love the low end Torq. of those little turbo's
Always run 91 Oct.
Always run 91 Oct.
