rebuild 94 f 150 5.0 liter
have a 94 f 150 flareside 5.0 liter, 5spd, 4x4: looking at buying a 5.0 liter to rebuild...first question.. what year 5.0 liter is 100% compatable with this motor...some folks are telling me any 302/5.0 block i can rebuild and use? other say only 94- 96 is compatable?
second question in my rebuid what will be compatable using my stock ECM? Id like to do flat head pistons, mild cam, some head work or heads? any suggestions? looking at spending $2500....thanks
on
Any '87+ 5.0 engine will have the same roller block as yours but it may not have a roller cam in it, but if you're replacing all the internals that doesn't matter anyway. If you were just swapping in a used motor then you would want a '94+ truck motor to be 100% compatable,
GT40 heads are probably the cheapest uopgrade, and just add 1.7 rockers with the stock cam which is already pretty good.
on
The stock pistons are pretty much flat top anyway, use whatever you like but make sure they have valve eyebrows(for future upgrade compatability) and static CR doesn't go above about 9.5:1.
Headers, yes shorties and longtubes are good upgrades. Shorties are easier to install and and you can even buy an aftermarket Y pipe with or without a high flow cat that will make it an easy bolt-on job. The motor doesn't need a cat to run correctly but all aftermarket cats are high flow compared to the stock units and will not hurt performance but they will clean up the exhaust some so there's really no good reason not to install one. Longtubes will produce the best low rpm gains but there are no intermediate pipes available to buy so you're on your own there, but it's not that hard to fabricate a single or dual system if you're at all handy with a welder or have a good exhaust shop nearby. In either case make sure the O2 sensor is reinstalled in the passenger side header collector(doesn't matter that it only "sees" one side of the motor), and do not use exhaust tubing larger than 3" for a single or 2.5" for duals. And chambered mufflers like those from Flowmaster drone badly at cruising speeds so I'd suggest something from Magnaflow or Dynomax.
Green Griffin 420
06-11-2012 03:54 PM
bigbad'945.0
10-28-2008 02:38 PM
gamudslinger88
01-15-2008 05:42 AM
irwin25
06-03-2007 05:27 PM
