73 f100 no brake booster?
Power brakes were optional in '73.
I would go through and check the entire brake system to be sure but manual brakes of yesterday are going to feel different than modern brakes.
If you add power brakes to the F100, you need to get the entire pedal assembly, the bell crank assembly that mounts the booster to the firewall and the booster/master cylinder.
My first guess would be the calipers or rear wheel cylinders have frozen from sitting.
The two pistons inside the MC could also be seizing inside the bore.
The inner linings of the flexible brake hoses can also break down and slough off over time and act like a check valve --either impeding brake fluid pressure/flow to the calipers or, allowing pressure/flow to them but slow about releasing the pressure, after you get off the brake pedal.
Out of curiosity, is the brake warning light lit up on your dash?
bigTRUCKdriver0786
12-12-2011 02:32 PM
evam350
04-29-2008 06:18 PM
Broken40
08-19-2007 06:00 PM
JermKline
09-22-2006 08:22 AM
rick
01-24-2001 03:49 PM
