6" glass round speed glass seal
Reconditioned the 65 instrument cluster and I was unable to salvage the 6" round spaghetti thin seal that sets inside the panel the glass sets into. I checked online part supplier's; Mac's, DC, LMC, Bob Drake, and Truck stop, with not success so thought I would check to see if any members know of a source? Now the 6" round piece of glass does not set flush with the panel, too loose. Comments/Suggestions appreciated!!
As a follow up and for info purpose only: As mentioned, I could not find the replacement seal between the round speedo glass cover and the metal instrument panel and was about to take Roberts advice of applying a dab of silicone when I came across the old 'dash to instrument panel seal' and did a trial fit and found it worked perfectly. The seal is grooved so I wrapped the seal around the perimeter of the glass cover and once I secured the instrument cluster to the metal panel the unit was snug. Anyhow, thought info may provide food for thought if member came across similar situation in the future.
http://cdnll.dennis-carpenter.com/im...TZ-17310-A.jpg
hoxiii
04-21-2008 04:40 PM
racoonbandit
03-23-2006 07:54 PM
packrat56
01-11-2006 11:35 AM
