6" glass round speed glass seal
Old 10-04-2015, 02:23 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
Reconditioned the 65 instrument cluster and I was unable to salvage the 6" round spaghetti thin seal that sets inside the panel the glass sets into. I checked online part supplier's; Mac's, DC, LMC, Bob Drake, and Truck stop, with not success so thought I would check to see if any members know of a source? Now the 6" round piece of glass does not set flush with the panel, too loose. Comments/Suggestions appreciated!!
Old 10-04-2015, 02:29 PM
gangstakr's Avatar
gangstakr
gangstakr is offline
The glass is 6 1/8" round. Most people when replacing that just use a few dabs of silicone to keep it in place. You don't need to overdo the silicone, just a few dabs.
Old 10-04-2015, 03:03 PM
daveengelson
Robert, I thank you, sounds like a good solution.
Old 10-13-2015, 03:29 PM
daveengelson
As a follow up and for info purpose only: As mentioned, I could not find the replacement seal between the round speedo glass cover and the metal instrument panel and was about to take Roberts advice of applying a dab of silicone when I came across the old 'dash to instrument panel seal' and did a trial fit and found it worked perfectly. The seal is grooved so I wrapped the seal around the perimeter of the glass cover and once I secured the instrument cluster to the metal panel the unit was snug. Anyhow, thought info may provide food for thought if member came across similar situation in the future.
http://cdnll.dennis-carpenter.com/im...TZ-17310-A.jpg
Old 10-14-2015, 08:58 AM
svolpone's Avatar
svolpone
svolpone is offline
I had the same problem. I just put a thin, clear bead all the way around. Held it perfectly. No rattle!
Old 10-14-2015, 09:50 AM
daveengelson
Agree, a few dabs of silicone sounds like a good solution and had I not been brain storming when I came across the used panel to dash seal and found it worked I was going to go that route.
Heinz5774
08-02-2019 02:41 PM
BlueovalFE
1947 and Older Ford Trucks
15
08-13-2012 10:10 PM
hoxiii
04-21-2008 04:40 PM
racoonbandit
03-23-2006 07:54 PM
packrat56
01-11-2006 11:35 AM
Quick Reply: 6" glass round speed glass seal
