replacement clutch
How many miles do you have on that clutch ? original ?
If it were mine, I would seriously considering of Motocraft parts.
You may need to think about several items;
1- Clutch disk , 2-Pressure plate , 3-TO bearing , 4- pilot shaft bearing ,5- resurface flywheel, 6- master & slave cylinders (especially if you have an internal slave cylinder).
Good luck,
Good luck,
How many miles do you have on that clutch ? 97000
original ? not sure
Good luck,
original ? not sure
Good luck,
I called a local shop (Rialto, CA) "Clutch Masters", they just quoted me $289 with everything but the resurfacing ($50 extra). Better than stock, but not a harsh engagement racing unit.
Anyone have any feedback on them?
I agree on the OEM parts, but................
I checked with the Motorcraft (Red & white label)supplier, no OEM parts are available. I called the local Ford Dealer for the (Blue & white label), they said they could order the throw out bearing, & the pilot bearing, that's all Ford sells.
NT
NT
Kijutsu
1983 - 2012 Ranger & B-Series
10-19-2007 03:50 PM
92F150XLT
12-08-2005 09:00 PM
92F150XLT
12-08-2005 12:54 PM
