Stupid question about mud flaps
Looking to order OEM "splash guards" (that's mud flaps to me) for my 2015 F-350, because even though its only been on the road for 10 months, the Tri-Coat white pearl paint is starting to come off where rocks and other road debris is getting kicked up behind each of the 4 tires. Not big pieces, just little nicks and chips. But of course, that can be an easy spot for rust to form, and start to look unsightly after awhile.
Anyway, Ford offers flaps "with wheel lip moldings" and "without wheel lip moldings." I see no difference in their picture. What's a "wheel lip molding?" How do these mount?
Thanks in advance
Thanks in advance
The molded ones come with bolts and nut clips....you remove the push pins and install the nut clips and then bolt up the molded splash guard......they work good on my 2015 truck similar to yours.
Wheel lip molding was the chrome trim around the wheel openings on older trucks and cars. Not sure what it looks like on the new trucks like yours. If you have something attached to the wheel opening on the outside of the fender lip (the inner fender liner would be attached on the inside of the lip), then you have wheel lip moulding.
Once you have those and have otherwise protected and retouched etc, consider this serving suggestion for vulnerable areas:
3M Paint Defender Spray Film - AutoZone.com
The whole lower edge of my Taco is sprayed with some crinkly extra thick protective paint-like substance. It looks worse than standard paint, but better than dings with rust in them.
My 2000 F-150 XLT used to have this too. It was a two tone truck, and the crinkly stuff was under the accent color along the bottom of the truck. Looked kind of like they sprayed undercoating on before painting it.
I don't think so - all the 2011-16 generation of Super Dutys have a "fender flare" which is made of steel and painted. Some trucks have two-tone paint ( like the King Ranch) but that's just paint.
TosaFords is right on this. Many of the upper trim level 2011+ trucks, especially with the two tone paint, have an additional OEM plastic "flare" that provides ~3/4" of additional tire coverage, is painted the secondary color, and would be considered the "wheel lip molding" which would change the shape of the mud flap. If you do not have such a thing, which it would seem you don't, then you want to order the no molding mud flaps.
But in any case, the no wheel lip seems appropriate for me.
Thanks
