Ford super duty transmission ZF 5-speed conversion
Bought a 2000 5.4 super duty 5 speed and just found out it wont fit in a 7.3 truck. just wondering what its worth.
Have the following items:
ZF Transmission with transfer case
Manual transmission crossmember
Pedal assembly (clutch and brake)
Slave cylinder (external)
Steering column cover and "push" tab for key release
Shifter
Shift boot
Clutch, flywheel and pressure plate
OEM 5 speed Transmission wiring harness
Front Drive shaft (shorter than auto)
Rear drive shaft (longer than auto)
Clutch fork
pivot ball
throwout bearing
pilot bearing
Clutch pedal position switch
Shifter
Shift boot
Clutch fork
pivot ball
throwout bearing
pilot bearing
Shifter
Shift boot
Clutch fork
pivot ball
throwout bearing
pilot bearing
Shifter
Shift boot
Clutch fork
pivot ball
throwout bearing
pilot bearing
Cahlager
09-17-2012 09:10 PM
