1993 f150 hazard light...
Old 09-25-2015, 10:36 AM
Thedonk's Avatar
Thedonk
Thedonk is offline
Originally Posted by 78 PEB
I have occasionally had problems with the flashers (4 ways) on my '96 especially after sitting for a few months. I just turn them on and off rapidly quite a few times. Apparently the contacts on the switch get dirty or slightly corroded. Cycling the switch rapidly cleans them up and then they work like they should. Ive also had the same problem with the turn signals and windshield washers........same solution for those as well.
thanks ill give it a try
Old 09-25-2015, 05:16 PM
choate's Avatar
choate
choate is offline
You push the button real fast and that makes it start working normally after that?
Old 09-25-2015, 09:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,363 Likes on 1,076 Posts
Originally Posted by Thedonk
because i dont wanna throw money at something till i am positive it will work
Did you try what was suggested in post #9 and swap the turn signal and hazard flashers? That wouldn't cost you a dime. If the hazard then works but the turn signal doesn't, you now know the flasher is defective.
Old 09-25-2015, 10:15 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
At this rate, it would take 3 or more pages just to check the engine oil!!!!
Old 09-28-2015, 09:52 AM
Thedonk's Avatar
Thedonk
Thedonk is offline
yeah i tried turning them on and off like a thousand times lol
Old 09-28-2015, 10:07 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
Not the lever and button, Donk. The Flasher itself, on the front and back of the fuse block.
Old 09-28-2015, 10:37 AM
Thedonk's Avatar
Thedonk
Thedonk is offline
oh -__- now i feel dumb lol
Old 09-28-2015, 11:15 AM
ncranchero's Avatar
ncranchero
It happens or has happened to everyone at some point. If that doesn't yield results you'll need to get to the plug on the switch.
Old 09-30-2015, 09:54 AM
Thedonk's Avatar
Thedonk
Thedonk is offline
ok so i got a new plug and it ticks but it doesnt flack on the dash or the outside lights... what do i check now???
Old 10-01-2015, 09:16 PM
My4Fordtrucks
Guess the flasher didn't do anything before? Next step is to check voltage into and out of the multifunction switch.
03bigred2
1999 to 2016 Super Duty
08-24-2018 09:13 AM
mmilesg
04-17-2009 01:31 PM
1980f150
06-08-2008 01:29 PM
Aggie05
Bronco II
19
04-04-2006 03:49 PM
jpsartre12
08-11-2004 11:41 AM
Quick Reply: 1993 f150 hazard light...
