Window Seal P/N?
on
Window Seal P/N?
Does anyone have a Ford Part number & source for the seals for the side windows on the 1991 XLT Lariat Extended Cab?
I think I may need to replace them, but can't seem to locate a P/N or source when i looked quickly... I understand they(along with the roof seam sealer) are a couple of the big leakage areas which help corrode the rear extension, and I want to replace them before winter hits. I am planning to replace the extension lower rust-out section & rear wheel opening areas as well before too long- don't like the idea of packing snow & crap in this winter...
Thanks-
Scott
Thanks-
Scott
I believe you can still get many of the seals from Ford. The part number for the window channel which I guess is what you are looking for, listed in the online catalog 21536. I believe that is just a base number, but is all that I see listed. Aftermarket versions are also available from Summit and so on.
on
I will check Summit- the other link did not have them listed...
Thanks!
Scott
Mark Twain
12-22-2017 09:07 AM
notthemaniusedtobe
26
04-02-2015 02:07 PM
F-100CustomCabTBC
03-09-2013 06:43 AM
JTS
01-24-2007 12:18 PM
