1957 F100 Marmon Herrington on Evilbay
Old 09-11-2015, 10:35 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
Did you guys see the so called 57 F100 MH on ebay? I sent the guy a message asking why he thought it was a MH and he told me he did his research and it has all the correct pieces. It looks to me like factory 59-60 Ford gear in a 57 shortbox. And for the record I do not know the seller and have probably pissed him off.
http://www.ebay.com/itm/Ford-F-100-/291560654315?forcerrptr=true&hash=item43e25e85eb&item=291560654315
Old 09-12-2015, 03:30 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
I didn't see any badging in the pics. Was anything said about that? I believe I may have seen this listed and portrayed as a M-H a few years ago. But with no proof of its history, just empty words. Stu
Old 09-12-2015, 08:26 AM
thundersnow70
I asked about the badges, he did not reply to that question. He also said while doing his research that it might be a "MH kit". He also said that MH did ALOT of gmc truck in the 50's. I didn't respond to any of those claims, it was late and would have probably sounded bad. It is a pretty clean truck with period correct gear. Ford gear!
Old 09-12-2015, 02:28 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
He updated the description at the bottom, and says that there are no badges, and it could be a 57 with 59-60 gear.
Old 09-13-2015, 06:09 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
If the original purchaser requested that Ford send the truck to Marmon-Herrington to be converted to 4WD, the DSO code on the Rating Plate would have 4 numbers denoting a Domestic Special Order.
Seller posted a pic of the Rating Plate, DSO is blank. There are no 'how to operate the 4WD' plaques on the dash. Every M-H conversion I've seen had at least one.
More than likely, a previous owner converted this '57 to 4WD using 1959/60 genuine Ford parts.
Old 09-13-2015, 06:37 PM
thundersnow70
Totally agree ND. After I seen the listing I was thinking I have never seen a 57 or 58 half ton MH. I have seen napco ford half tons in those years but never a MH. I did a google image search and also came up with nothing. It just got me thinking what front axle MH would have used in there version of a 57-58 half ton or 3/4 ton.
Titantis
57
05-19-2022 12:20 PM
1986F150six
08-03-2016 11:05 AM
gangstakr
17
01-29-2010 02:51 PM
jdbanks
05-29-2003 08:58 PM
Quick Reply: 1957 F100 Marmon Herrington on Evilbay
