Removing later paint and cleear from original paint
I have a 1955 F100. PO sprayed cheap silver paint right over the original turquoise paint and a clear coat over the silver. I want to remove the clear coat and silver to expose the original paint. Where the clear coat is already gone from UV, I can remove the silver with lacquer thinner and fine steel wool and some elbow grease - and the original paint underneath isn't harmed. But where the clear coat is intact over the silver, the lacquer thinner doesn't do anything.
I've thought about sanding with a super fine grit but I am worried I'll quickly eat through the thin silver layer that's between the clear coat and the original, and cut into the original paint.
Does anyone have any ideas how to remove the clear coat without damaging the original paint?
Since car manufacturers first began using clear coat, car owners have debated on how to remove it when it fails. There is a simple answer, sand it off. I am not sure why you would want to remove a top coat while attempting to preserve the paint underneath it but have you considered how much work the painter put into preparing the original paint for the current paint job? You have a lot of faith in the assumption that the original paint is in good condition...why not prep the truck and paint it the original color?
