Extra parts in my master cyl/pedal set up???
Old 09-03-2015, 08:22 PM
Mitch1129's Avatar
Mitch1129
Mitch1129 is offline
Like I said all my lines are pre-bent and match-up to my new set up also. Lemme know if this helps?
Old 09-03-2015, 08:26 PM
Mitch1129's Avatar
Mitch1129
My problem was I bought the truck from a guy that didn't build it so he had no clue what was on it. Master cylinder went and I couldn't find out what type of vehicle it was off. Same with front brakes. So a bought new everything so I would know what everything was. Bought this complete kit off eBay. Very similar to my set up just not exact. Thank you for the help so far. Just want to get this figured out.
Old 09-03-2015, 09:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Residual pressure valves go as shown
Old 09-03-2015, 09:05 PM
Mitch1129's Avatar
Mitch1129
Ahh gotcha. So I can leave the two separate lines going to my front brakes and it should work properly?
Old 09-04-2015, 07:29 AM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is online now
Not all systems need the residual pressure valves. For what ever reason a lot of people on here think they are necessary. I have a stock location M/C and do not have residual valves and the is no adverse effects in my system. The valves became real popular with the new after market small reservoir M/C's. I say if your existing system worked fine replace you M/C and confirm it works fine, if not you can always add the valves after the master install. The effect of not having the valves is there is more pedal movement prior brake application, that is all. Your brakes will still work without the valves.
Old 09-04-2015, 10:04 AM
ALBUQ F-1's Avatar
ALBUQ F-1
His original MC may have had RPV's in the MC ports.
Old 09-04-2015, 12:25 PM
truckeemtnfords
Ross,
True, but the new one may have them as well. A lot of the late model m/c's do have them. It can be determined by testing with a pressure gauge or visual inspection by removing the seat in the port and checking for the check valve. Being that his replacement is direct bolt in per the OP, putting in the new m/c and then determine if he needs the residual pressure valves. It is not a big deal to add them after the fact.
He said it was a kit he bought on ebay. A lot of those sellers just throw parts in their kits, needed or not, because they (seller) don't have clue what they are selling.
Old 09-04-2015, 01:56 PM
jimcar-9's Avatar
jimcar-9
jimcar-9 is offline
Just get a T-coupling and connect the two front ones, then place the 2 psi residual valve between this T-coupling and the MC. Preferably as close to the MC as possible
Old 09-05-2015, 08:28 AM
Mitch1129's Avatar
Mitch1129
I'm going to try i, hope it works. Going to get lines bent with the res valves in it..
PIGGYONAHOG
05-22-2019 12:13 PM
thekingofcows
02-28-2018 06:50 PM
arrowheadfred
15
02-27-2011 10:57 AM
g84t8f1
24
09-25-2006 10:20 PM
twobike
13
05-25-2003 08:52 PM
Quick Reply: Extra parts in my master cyl/pedal set up???
