I have a 1953 F100. I have front disc brakes and rear drum brakes. I have installed a 1977 mustang booster and master cylinder. I plummed the front brakes from the large chamber at the rear of the master cylinder that has1/4" line and the rear brakes from the small chamber at the front of the master cylinder that has 3/16" line. I need to know if this is correct since I am having the front disc brakes lock up and only release when I open the bleeder valve.
It sounds like you don't have aporportioning valve in your brake system. The lines from the master go into it and then out to the 4 wheels. This regulates the amount of pressure to the fronts and rear. You probably are getting too much pressure to the front calipers, they use much less than the backs to work. They even make adjustable ones so you can regulate the pressure.
Yes, I now realize I need a proportioning valve and inline check valves. But I still need to know if I have the right lines going to the right chambers in the master cylinder before I plum in the new valves.
Just to make sure we're clear on one point, disk brakes are generally designed to operate at between 500 and 1200 psi, maximum. Drum brakes are generally designed to operate between 250 and 600 psi, maximum. The are, of course, going to be exceptions to these ranges. The numbers I saw for a typical 1970's sedan with a disc/drum setup is 1000 psi front, 300 psi rear.
I would definitely get a proportioning valve on it ASAP. I assume you mean residual valves when you said check valves. I am not so sure you will need anything more than a proportioning valve. Also ensure the rod that enters your master cylinder is properly adjusted. If it's adjusted too long you can get similar symptoms.
Twobike, Is it both front brakes locking up or just one? If you cracked the line at the master cylinder will the front brakes unlock? I have found this problem on lots of different cars and trucks if it is not the master cylinder witch could be. It is some thing cloging a tube or a hose. I find a lots of hoses. The reason this happings is that your foot can push the fluid past the blockage but cain't return. The brake lines are hooked ok. And a proporyioning should be used but the the brakes should not be locking up.
I recently installed a similar system on my 56. The main difference is I used a 70 Mustang master cylinder because it is a 1" bore . Not sure what the 77 bore is. I plumbed the front disc brakes with 3/16" lines as per recommendations of ECI Brakes and CH Topping. They indicated that 1/4 was ok on the rear but not on the front. So I believe the plumbing line size is incorrect. I believe disc brakes need 3/16 line and the drums can be plumbed either way. You might want to call one of the places and check that out. I found them to be very helpfull. I
As already indicated in other responses, you will need a proportioning valve or combination valve, before you hit the streets. As far as check/residual values you definately need one on the drum line but usually this is built into the drum brake portion of the master cylinder. You would only need one for the disk brakes if the master cylinder sits below the disc brake wheel cylinders.
Got it all back together with proportioning valve and residual check valves. 10 lb. rear, 2 lb. front. Still have 1/4" line in front, but may have to change it. Drove it about five miles and it worked fine. Didn't lock up. A longer test will tell for sure. Thanks again for all the help.
"As far as check/residual values you definately need one on the drum line but usually this is built into the drum brake portion of the master cylinder."
Rick
I didn't think he would likely need a residual valve, but I don't know how to determine if it is built into a particular master cylinder. I would be interested to know how to determine this, if you can explain it.
Originally posted by fatfenders "As far as check/residual values you definately need one on the drum line but usually this is built into the drum brake portion of the master cylinder."
Rick
Thanks
There is a spring and check valve inside the line port(s) of the M/C. To remove the check valve, take a wood screw and thread it into the brass part in the center and pull it out. There is a spring and piston in there.
Normally disk run with about #2-3 and drums have #8. Wilwood sells a cool little inline residual valve and adjustable porportioning valve.
I am running the stock '55 m/c, a Midland hydroboost, and the Wilwood residual and porportioning valves.
Rick
Thanks
fenders,
check out this article on chtopping's web site http://www.chtopping.com/example7/example7.html. in section 9. it shows some pictures and explanation. i think the article will do a better job than i could ever do in explaining it. this article is talking about mustang mcs, but i think this could be extrapolated to other mc (?), because everything i've read to date implies you need a 10 psi residual check valve on drums to counter the springs on the drums. perhaps it may be incorporated into some combination valves, but i've never heard or read about that being done and it wouldn't be cost effective to manufactures to install inline residual valves.
