Motor tranny help
Old 09-02-2015, 09:24 PM
Hondaman416's Avatar
Hondaman416
Hondaman416 is offline
Motor tranny help
Ok I have a 79 f150 4x4 short bed with 351m and c4 trans I have 78f250 parts truck 2x4long bed with 390 c6 I want to put 390 in 79 4x4 I have read the trans won't mount up so what do I do can I can't bell housing or what looking for ideas adapter plate maybe ?
Old 09-02-2015, 10:47 PM
Jklnhyd's Avatar
Jklnhyd
Jklnhyd is offline
You dont really have a parts truck, it sounds like you have 2 trucks.
There is going to be expensive fabrication work between:
351-390
C4-C6
F150-F250
2WD-4x4
Your cheapest, easiest, and most reliable choice is to rebuild the 351 and upgrade the cam, heads, intake, carb, add headers, etc.
Old 09-02-2015, 10:52 PM
Hondaman416
Your right I have two complete trucks I want 390 it hAs very low Miles I would think buying used c6 for 390 4x4 be cheaper than rebuilding 351.
Old 09-03-2015, 04:43 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
you dont have a c-4 in the 79 4x4 either. It has to be a c-6. Still wont bolt up to the 390 though. By the time you buy a tranny that will bolt up to the 390 and do all the other alterations necessary you should be able to build a good 351m/400
Old 09-03-2015, 04:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Hondaman416
Ok I have a 79 f150 4x4 short bed with 351m and c4 trans.
I have 78 f250 parts truck 2x4 long bed with 390 c6.
No 351M in a F100/350 came with a C4, the only A/T available was the C6.
1976 was the last year 360/390 engines were available in F100/350's, but 4WD's were only available with 360's.
Old 09-03-2015, 08:57 AM
Hondaman416
Ok guy I'm not sayn I'm not grateful for replies but we are getting of subject. I didn't ask if I should rebuild 351 or not. I asked how to make it work in truck. So please let me know what can be done a used c6 can be had for well under 500 bucks.
Old 09-03-2015, 11:25 AM
Alexz265's Avatar
Alexz265
Alexz265 is offline
Well, you would need a C6 4x4 trans with the FE bell housing (totally round, not trapezoid top). Also, you would need the engine towers for the 4x4 truck for the 390. The other than that, it should be fairly straight forward in concept. As they said, could be pricey with all of the little things that come up. The the FE automatic should have the NSS switch in the steering column. The other may have on trans. Though, this can be rectified with simple wire splicing. Driveshafts should require no modification.
Old 09-03-2015, 11:27 AM
Alexz265's Avatar
Alexz265
Alexz265 is offline
Also you will need the 390 to be a rear sump oil pan.
Old 09-07-2015, 01:39 PM
Hondaman416
Well I think I'm going to hold off of the swap it runs fine I just want bigger better motor. Maybe some day
1994F2507.3L
17
11-01-2023 02:33 AM
F-150_XL
07-24-2009 07:53 PM
The R2
02-26-2008 01:08 PM
Bulldog187th
09-09-2004 10:41 PM
cowboy_lurch
02-03-2001 06:30 AM
Quick Reply: Motor tranny help
