safety issue.....brakes....help
#46
#49
No... That's what my old shoes looked like and brakes stopped with firm pedal. Then I put new brake shoes in and replaced a fluid line and had no pedal... Spent a day bleeding brakes all around before I took it in and found out I hadn't adjusted the shoes far enough apart!
#51
Rear brakes I just go with whatever generic Napa kit, they last a long time and you will probably never have to do them again.
Yeah once you get that replaced and hub and wheel installed, reach in with a screwdriver from backing plate and turn star adjuster till you get a touch of friction happening.
When you're doing the brakes make sure the star adjuster is catching.. Sometimes you have to bend/ tweak it a bit to make sure it catches.
Have both hubs off and only do one side at a time so you can reference the other side if needed.
#53
#54
It's good practice to use a spring kit, new adjuster cable. Clean up the adjuster and use anti-sieze. Inspect wheel cylinders for excessive leakage. It's easy to get carried away, but replacing wheel cylinders and rubber hoses, shoes, and springs won't hurt anything and isn't high buck maintenance. Inspect drums carefully for cracks.
What CAN happen, not saying it will - when cylinders run all the way out for a long time, (worn drums, worn shoes) a ring layer of corrosion builds around the cups and pistons in a certain spot. New shoes and drums means the wheel cylinders start to leak soon after.
Front brakes provide maybe 70 per cent of the stopping power, but rear brakes hardly ever get serviced.
