Low budget carpet
PT Cruiser. Leather and suede. Plenty of room. I centered the drivers side to the steering wheel and placed the passenger to match. 6 inches to the door panel and 2 inches between the arm rests in the center.
front bracket is factory seat bracket. Had to weld up some square tubing for the back. Front is perfect height the was it is. driver side is power, but up and down only (why?) slider and back are manual. Pt cruiser seat belts are mounted in the cab corners.
Hey Rick, I went to Home Depot with hope. Returned with no hope and no carpet. Could find no pre-cut carpet 5' x 7". Found black carpet on rolls but they were room size. Did find a small random sample of thin black carpet but it looked like the fury half of Velcro. Like it would hold debris and never let it go. In your pic yours looks like it may be leaning toward a loop style. I asked an employee and they couldn't help. Before I go to another Home Depot can you provide any more info that might help me find it? Thanks
Mainstays Titan Area Rug - Walmart.com
Yes it is a loop style carpet with bound edges. It actually measures about 58" across. A hair too narrow but the 2" aluminum carpet strips cover that and a little extra cut from the toe board end finishes the cab corners. I found the exact same carpet at Walmart as well. I think this is it.
Thanks for the additional information. I feel confident that it will lead to success. I'm going to buy one to cover up the ugly and stay clean while in the cab, and if I ruin it in the process I'll buy a second for the finish. Assuming there will someday be a finish..
jrockdiddy
05-16-2013 05:07 PM
tommynos
Ford Truck Parts for Sale
04-11-2010 02:08 PM
48' fordster
11-09-2005 10:41 AM
