Replacement for Ford F6 Axle 2 speed
I'd suggest a Dana 70HD, commonly found in '70/'80s Dodge RM400/500 based motor homes. They have a 4.56/1 ratio, and are almost a bolt it swap to my measurements. They have your same 5 lug x 8" bolt pattern. I had one intending to do a big truck myself, but came to realize I wasn't gonna get it done. The spring pads are about 1/8" off on each side, which can either be moved or dressed up to align with the springs. Finding a dead motor home isn't hard, and commonly they have tubeless 19.5" wheels that will work great on an F-6 too. Stu
There were front disc brakes on some of the RM400/500 motor homes. I still have a set from my aborted project. Whether the whole front axle would swap in I don't know. Would suspect there'd be issues adapting modern internal steering architecture to the F-6's outside frame rail pitman arm and drag link configuration. Stu
Thanks for both comments, now see there are options open to me. I hate to abandon this frame and body, she's a crowd pleaser and being an old girl, needs some new foundations so to speak.
The rear axle I had now sits under an F-5, and I know of the exact same swap that was done on an early '50s Studebaker 1.5 or 2 ton. My hope was that the motor home front spindles would be close enough in size to the Ford spindles to allow, assuming some machine shop help, the hubs and disc brake components to bolt on thus avoiding having to mess with steering geometry. But I never pursued the project that far. Stu
turnkyle
20
04-05-2015 10:08 AM
1949 F6
13
09-13-2011 06:13 PM
