Blown Turbo Hose?
Blown Turbo Hose?
2012 F250 Lariat 6.7 diesel pulling a 40ft Forest River Sandpiper 5'er 15k.
Was just pulling north on I81 in Mid Virginia coming out of the smokey mountains. Started in Houston earlier in the week and did 500 miles per day. I was 350 miles into this pull on our way to Virginia. I was running 68-70MPH
I told my wife this was the first time I could feel the trailer behind us. It felt heavy today but the truck was not showing any signs of being sluggish.
We heard a pop and the exhaust brake kicked in almost to a fail safe mode and I had no power and crawled to the side of the road. we thought it was a blow out, but we had control of the vehicle.
roadside assistance carried the truck in. In Idle, the truck sounded normal, but once you hit the gas it was jerking and had little power.
Ford Dealership says it is just a blown turbo hose...however, they provided a smart *** comment about well he had to be doing something for this to happen.....
After a recent torque converter failure and a blown pinion seal in the rear and I am starting to have some doubts...
Thoughts? 1. Is there anything else I need to have the check besides just hose and B. is this truck not able to pull a 15K trailer?
Another point of info, wife thought the exhaust brake was driving RPMs to high. is there anything to the exhaust brake running too high in the mountainous terrain.
did the hose rupture or just become disconnected. in 05 i had a new ram cummins with only a few hundred miles on it. pulled out to pass another vehicle and the bottom hose just slipped off. guess the clamp wasn't tightened at the factory. after i discovered what was wrong, i just loosened clamp, put hose back on and re-tightened the clamp. had it checked at a dealer a few days later and they said all was well. whether yours ruptured or just slipped off doesnt matter. you should be good to go again.
had the same thing to happen a few years ago on a loaded big rig. it would barely pull the load to the next exit where i could get it repaired.
yep, been down that road. Bottom hose on the driver side came off. The hose clamp actually broke right at one of the spot wields. This was on a very steep climb pulling my 5th wheel in the North Carolina mountains around the Linville Falls area. I thought the sucker had blown up. Never could have imagined any motor smoking that much! Mine is tuned but I was running stock power. Anyway 300 bucks later and I was towed the last mile up the mountain and the tow truck driver replaced the clamp for me. Don't know why but the hose that came off was Teflon and the other 3 are regular rubber hoses.
As to your trailer weight, I have over 26,000 miles out of 73,000 miles pulling my toy hauler, which weighs anywhere between 16,000 - 19,000 pounds. And we have pulled it all over from Arkansas to New Hampshire. Pulls it fine, just the lack of an exhaust brake which will mean replacing the truck when the 17's roll out.
So, the update?
georay
1999 to 2016 Super Duty
08-26-2015 09:37 AM
janinelucas
08-13-2007 05:32 PM
