Distributor help!!!
Old 08-20-2015, 08:31 AM
Ed2's Avatar
Ed2
Ed2 is offline
Distributor help!!!
1988 f250 5.8l. I had engine rebuilt, it now has about 100k on motor.
I am on distributor #4 since rebuild. What happens over time is the distributor
seizes up and the gear shears the pin. I just put in my 4th distributor
and I am frustrated trying to determine if its the engine, or every
distributor is cheaply made. This has nothing to do with the distributor or cam gear. The shaft becomes very tight to spin.
Has anyone experience this issue? Any ideas what could be the cause? We are talking about less then 25k on a each.
Old 08-20-2015, 08:33 AM
dixie460's Avatar
dixie460
dixie460 is offline
Are these Ford distributors or aftermarket junk?
Old 08-20-2015, 09:08 AM
Mule420's Avatar
Mule420
Mule420 is offline
You shouldn't be going threw distributor like that no matter if there aftermarket or not. I switched over to the msd that I have now after my stock ford one went bad . The msd distibutor been in my truck two years with no problems. I'd have to say it's sumthing in the motor if the gear is chearing the pin . Not 100% sure Whats causeing it just a guess. maybe sum one else will no good luck
Old 08-20-2015, 02:40 PM
dixie460's Avatar
dixie460
dixie460 is offline
Yeah but he didn't say whether he had been thru several different brands or several of the same brand.
If it's several of the same brand of aftermarket or aftermarket-rebuilt distributors then yeah I can see why they'd fail one after the other. Some brands just suck. For example, I'll never buy ANY hydraulic component that has been rebuilt by A-1 Cardone.
Old 08-20-2015, 05:14 PM
Toplait's Avatar
Toplait
Toplait is offline
What oil pump and shaft are you using in your engine?
Old 07-31-2022, 07:33 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,363 Likes on 1,076 Posts
This thread from Aug 2015 came up as a “related thread” to one that I was reading.
Ed2, I see you were active back in March of this year. I am curious if you found the cause of your distributor failures. You asked for help determining the cause and then never came back…..
The following users liked this post:
NICKSAN
25
03-01-2020 03:56 PM
djmichael24951
02-11-2014 02:59 PM
dave2180
02-07-2009 08:44 PM
thenipster
12-07-2006 04:30 PM
OneFine69
12-28-2002 01:47 PM
Quick Reply: Distributor help!!!
