Vss help needed pcm swap/c6/9"
swapping a SD efi 460 into a old SODA shortcourse 2wd race truck
has a c-6 and fabbed 9" diff. using a 97 f250 460 zf5 4x4 pcm and parts of the harness. no instrument cluster
looking at how to install a vss sensor.
have looked at the sensor from my 89 4x4 with e40d could i just use that sensor for vss? its the one where there is a drive cable but also electrical to.
and just throw it into the original c-6 speed cable hole????
second question that should have been first,
Do i even need the vss? i know itll run but will it run at its best? or trip the mil
It probably will trip the MIL but who cares if you don't have a cluster... not like it will be something you have to stare at.
Should not affect engine operation at all, especially with a PCM from a truck that was manual trans to begin with. My truck ran fine when my PSOM took a dump (same effect as not having a VSS) and my truck has an automatic so the PCM is definitely looking for that signal.
Dean06919
04-21-2015 06:05 AM
Beefcake09
06-29-2010 04:11 AM
dcc9075
04-20-2004 12:56 PM
