LED replacement bulb info, dont bother with them
Thanks to all for your information and opinions. After looking at the choices, for me, it seems the LED's are a solution in search of a problem - especially if you consider the low prices, availability, and the long service life of the incandescent bulbs.
Just my opinion.,...jack
Interesting input. Thanks guys.
Ron Francis Wiring is offering these 1157 LED replacement bulbs.
LR-57 RED - Staggered Pin Double Filament LED Bulb-Ron Francis Wiring
Of course at $27.95 EACH they aren't cheap.
AXRacer,
Thanks for the input on making the inside of the turn signal housing reflective. I am rebuilding my 48 F1 parking light housings and was trying to figure out how to make the inside reflective while painting or powder coating the outside to match the grille.
Phil
AXRacer,
Phil
I would think a 1947 is a 6 volt. Yes? There are no 6 volt LEDs that I'm aware of. 12 volt LEDs will work on a 6V but will be nearly half as bright as a 12V they were designed for. I have a 6V Farmall tractor and did extensive research on LEDs for it as the vibration of the tractor isn't so kind to the incandescent bulbs.
Bently_Coop
1999 to 2016 Super Duty
104
09-19-2019 11:58 PM
TNT in Round Rock
12-31-2008 08:04 PM
