Knocking Noise
I'm more concerned about the some at startup. Could be an egr cooler failure..... That can lead to hear gasket failure.
If you want to save your self big dollars , first get your self a gauge, most us scan gauge2 then enter the ford PIDs . I"ll make a list of Idems to look at and test
1. Last fuel filter and water separator change. Only use OEM filters
2. FICM, need to monitor main power MP, Vehicle PowerVP , Logic Power LP , do this test cold start koeo ( key on engine off ) low ( in park just sitting at Idle )
3. alternator test , you don't want anything lower than 13.3 on full power meaning HVAC fan on , lights on, radio, wipers, Etc.
If we can knock these out in Values are good then we will go a step further
yendor0801
6.7L Power Stroke Diesel
06-28-2011 09:30 AM
