Alternator - 110A vs. 135A - Single vs. Dual
Old 08-17-2015, 04:37 PM
allingeneral's Avatar
allingeneral
allingeneral is offline
My 2006 6.0 has a single alternator setup, and the alternator needs to be replaced. Can I replace it with the 135A alternator that's designed to run as the upper alt for the 2-alternator setup?
Old 08-17-2015, 05:26 PM
Will Bite's Avatar
Will Bite
Will Bite is offline
Yes you can. I did it a year ago plug and play.
Old 08-17-2015, 05:37 PM
allingeneral
Thanks! Did you have to grind your alternator bracket for clearance? From what I can tell, the 135A unit has a larger casing.
Old 08-17-2015, 05:40 PM
Will Bite's Avatar
Will Bite
Nope it bolted right up.
Old 08-17-2015, 08:42 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Even the old style 3G case bolts right up. The shop that built mine did some grinding on the bottom of it but I don't think that was even necessary on a 6.0 engine. (Sorry about the crappy picture).
Old 08-17-2015, 09:23 PM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is offline
Received 2,075 Likes on 1,405 Posts
And this is a Leese-Neville 230 amp unit used in emergency services. Bolt and plug, no adaptor needed either.
Old 08-17-2015, 10:44 PM
evan1242's Avatar
evan1242
evan1242 is offline
Looks nice jack.
What's the cost of that beast?
Old 08-18-2015, 12:27 AM
TooManyToys.
I know XDP sells them for about $350 and I believe Nations Alternator Starter also carries them and a higher amp unit in the same lineup, as well as other manufacturers. L-N is standard equipment in many commercial and transit vehicles. I may be trading my truck in this fall so I'll put the 110 back on and resell this if I do.
When I installed this one I put the 110, 140 and this one on the bench. This one just outsized the others. And just after the motor starts with the GPs still on you just watch the voltage climb back up.
Old 08-18-2015, 04:20 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
If you go with the 135 AMP get the smaller pulley.
You will find that the voltage will come up sooner at idle.
Sean
6.0L Tech Folder
Old 08-18-2015, 11:17 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Look for a 140 amp versus the 135 and look into getting the 58mm pulley
Josh
Old 08-18-2015, 12:25 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
I used Advance Auto, ask for the 2005 model, it's 140amp unit. Use coupon code TRT30 and save $50 off the price. Buy on line and do in store pickup.
Old 08-18-2015, 12:29 PM
xaviar's Avatar
xaviar
xaviar is offline
Deleted by xaviar
Old 08-19-2015, 10:36 AM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
crazy that the 230amp is plugNplay. I would think the wiring would need upgraded to handle this larger output no?
Old 08-19-2015, 10:50 AM
diesel_dan's Avatar
diesel_dan
diesel_dan is online now
Mine came with the factory 140A but I did what Josh and Sean are saying and put the 58mm pulley on and it jumps right up even with GPM still active...
And TooManyToys: I had the same Q as Kemicalburns -- I would think a wiring upgrade would be needed?
Old 08-19-2015, 11:29 AM
TooManyToys.
Sorry guys, my term plug and play was to if you need an adaptor for the regulator connection. Yes you do need to add an additional wire from the output terminal to the passenger battery terminal of 4ga (mine is 2ga)and a fuse of 125-150 amps in combination with the factory wires.
Quick Reply: Alternator - 110A vs. 135A - Single vs. Dual
