mysterious rear end squeak
Received 3,117 Likes
on
on
Look at them closely. See if therebis a rust colored residue where the rubber seals are.
If you dont see anything you can remove the driveshaft and see if they move freely.
u joints usually saeak at a higher frequency than tire speed. Is the noise once per revolution
or 3-4? You could get someone to drive past you as you listen for the noise. You should be able to tell
what area or side it is coming from.
Braydenv57
08-30-2016 05:36 PM
nix4x4
04-01-2010 01:20 AM
bertcakes
05-12-2004 09:15 PM
