Sponsored by: Real Truck
Two wierd sounds..
Old Nov 14, 2008 | 06:04 PM
laka's Avatar
laka
Two wierd sounds..
On my 04 F250 I have to wierd sounds that I can't seem to figure out.
1. When driving at slow speeds (probably present at higher speeds but wind drowns it out) coming from the rear are of the truck it sounds like a dull rubbing noise. Almost as if the rear brakes were shot and were constantly rubbing. I've jacked the back end up and spun the wheels by hand and can still hear the noise. Brakes are all good, and nothing is binding. Maybe a bad axle bearing?
2. When driving at slow speeds and I put the transmission in neutral and coast, after a couple seconds there is a little "thump". I suspect maybe the rear slip-joint as there is a little rotational play in there but nothing too bad.
Any suggestions?
thanks
Old Nov 14, 2008 | 06:37 PM
ReAX's Avatar
ReAX
Do you have a driveshaft carrier bearing?
Old Nov 14, 2008 | 07:37 PM
laka's Avatar
laka
Yep, is there a way to check and see if it's good? or just stick my head under when someone spins the tires?
Old Nov 14, 2008 | 09:02 PM
carls 250's Avatar
carls 250
Are you sure you don't have ebrake shoes coming apart
Old Nov 14, 2008 | 10:11 PM
ReAX's Avatar
ReAX
You can probably grab the DS and wiggle it. The bearing should only allow minimal movement, if it feels loose, you probably need to replace it.
Old Nov 15, 2008 | 12:17 PM
laka's Avatar
laka
Thanks for both the ideas. I'll do some more investigating.
