I have a 90' Ford Ranger, rear wheel drive.
I can not find a 2 wheel drive automatic transmission and I was wondering if I can convert a 4 wheel drive transmission?
Swapping the output shaft requires disassembling the entire transmission. It's basically the last thing to be removed. If you're comfortable taking apart both transmissions to swap the output shaft (assuming your old one isn't damaged) then you can use yours.
