Converting a 4x4 transmission to a 2x4
Old 08-11-2015, 11:09 PM
Martin666's Avatar
Martin666
Martin666 is offline
Unhappy Converting a 4x4 transmission to a 2x4
I have a 90' Ford Ranger, rear wheel drive.
I can not find a 2 wheel drive automatic transmission and I was wondering if I can convert a 4 wheel drive transmission?
Old 08-12-2015, 12:22 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,719 Likes on 1,404 Posts
Welcome to FTE.
You would need the output shaft and tail housing--in other words, a donor transmission. Keep looking.....
Old 08-12-2015, 01:22 AM
Martin666's Avatar
Martin666
Originally Posted by 85e150six4mtod
Welcome to FTE.
I have the old transmission, will that work?
Old 08-12-2015, 08:03 AM
exranger06's Avatar
exranger06
exranger06 is offline
Swapping the output shaft requires disassembling the entire transmission. It's basically the last thing to be removed. If you're comfortable taking apart both transmissions to swap the output shaft (assuming your old one isn't damaged) then you can use yours.
jayloveland
03-28-2015 01:52 PM
mjm1
04-09-2011 07:57 PM
aceltx09
1999 to 2016 Super Duty
08-10-2010 07:30 PM
snubber
10-29-2008 11:58 PM
Fordzilla_4X4_King
09-12-2003 11:19 PM
Quick Reply: Converting a 4x4 transmission to a 2x4
