ZF5 transmission adapter kit for 400...getting closer
Not true, it's good info. The main difference between and 80+ vs the earlier Bronco is simply going to be the pedal assembly, trans tunnel clearance (including the cover plate), and perhaps the t-case. Not sure what t-cases were used in the 80+ Broncos. The '78-79 came with only 203 or 205 units.
Ask Tim. But I know he makes the adapters and drills 400 flywheels to accept 460 pressure plates. And, I think he has the place bolts to bolt the flywheel through the adapter to the crank. And, with those pieces you can use a 460 clutch kit and bolt s ZF5 up to a 400.
In a way that's a kit, but it doesn't have instructions so it is a box of parts.
It's a kit.
If you search the forum or google, you'll find a lot of talk about it, and the link to buy the kit.
Here you go
ZF5 adapter kit
Here you go
ZF5 adapter kit
Gary Lewis
09-16-2015 05:09 PM
Gary Lewis
08-18-2015 05:25 PM
