1995 F-150 headlamp assembly replacement
You'll have to remove the battery. There are two 10mm nuts on the back of the turn signals that you need to remove. Remove the two screws holding the chrome trim piece down (the ones above the headlight). That will allow you to remove the trim piece/turn signal/side light and gain access to the headlight. For the drivers side, you need to remove the bolt holding the coolant/washer tank. There is enough room in the hose for you to set it ontop of the airbox and use a strap or rope around the hood spring to hold it in place. Do the same procedure as the other side. To get the headlights out, I just unscrewed the 3 adjustment screws because the sockets were fine and I didn't see a need for changing them.
Sam's1967
05-28-2015 05:01 PM
fstbck1970
07-21-2014 01:46 PM
