Yes, they are reuseable. I believe the correct gear backlash is .002 - .006. The max cam end play is .006. I'm doing this from memory, but that is the right order of magnitude.
Thanks Frenchtown Flyer! Hoping after i pick up a cylinder ridge reamer and pull the crank i can figure out if this 66 had a forged of cast crank.
Thanks again for your time knowledge, Jon
